Power Tilt Trim Motor - Whats It For
YOUWILLLOSE
:confused:
I know silly question
I have a merc power tilt/trim motor brand new in the box, I am trying to work out what motor's it will fit.
The box states the following on it
D.C MOTOR - 111862
BARCODE THEN NUMBERS BELOW IT ARE - (01)95705541053062(30)1
THEN IT HAS 1105 UNDER THAT FOLLOWED BY 010-oe-S1
PRICE WAS RETAIL ?464.55
SOME ONE TOLD ME THE PART NUMBERS WERE 176494A1 or 87828
ITS THE SQUARE TYPE WITH 3 WIRES
I have pics if it helps you. Just looking to know the hp range/year if possible thanks
YOUWILLLOSE
Re: Power Tilt Trim Motor - Whats It For
PIC SUPPLIED, I have no clue what im looking for sorry
AMD Rules
I'm not sure.... but the Merc website shows this:
P/T Pump Motor
The part: 87828 has been substituted with: 17649A02 17649A02
For Oildyne P/T pump w/plastic reservoir
I believe that is a Mercruiser pump
Laddies
Banned
Yup, thats a Mercrusier trim pump
YOUWILLLOSE
Pardon my stupidty, does that mean it wont fit any mercury outboards ? if anyone knows what it may fit could you advise thanks
AMD Rules
Assuming your trying to find a cross-reference list so that you can sell it? Google may provide much of the information you are looking for.
It will fit any Mercruiser that uses an Oildyne pump. It may fit some older outboard applications as well, where an external trim pump was applied but would not be original. Many people converted from the original external trim pump to the mercruiser pump (w/plastic reservoir) when thier original systems failed.
Toss it up on eBay with the part numbers you have already, make reference to Oildyne, and chances are anyone searching for it will be able to find it.
Good luck.
