power tilt/trim 1982 johnson 90hp v-4
alanR1
my tilt/trim on my johnson has started to slow down significantly. It is going down slowly and not coming up without a little help. Any suggestions on what to do with it. I have the OMC service manual but I was hoping to get some input from someone on here with experience. Any help is greatly appreciated.
The Marine Doctor
Re: power tilt/trim 1982 johnson 90hp v-4
It is possible that your motor is getting tired or the Thru tube could be corroding.<br /><br />You could also looses the steering nuts a tiny bit and see if this helps. They are the large nuts on either side of the thru tube.<br /><br />TMD
alanR1
does anyone have any suggestions on how to service the tilt and trim unit on these motors?? Any help is appreciated...
