C. Lindberg
- Sep 1, 2015
- 3
Is it possible to remove the entire power tilt unit intact from inside the boat? The ram extends outside the boat and has a limiter nut on the end. Currently the unit is not working so have been unable to extend the ram to inspect the limiter nut or attempt to remove.
It appears to be the original unit. It's in a 1972 Chris-Craft XK-22 and the outdrive is a Volvo-Penta Aquamatic (AQ270) I'm trying to source a good, used power tilt unit as a replacement. Are resistors, limiter switch and motor still available to repair the inoperable one?
Thanks!
Thanks!
