Power tilt question
MoFish76
I have a 1999 50hp Johnson 2 stroke (J50PLEEA) When using the power trim, When going down it has a clicking noise that sounds to me like it's coming from the motor area. When going up there is no noise. It seems to work fine. Fluid is full and battery is new. Any ideas on what is the noise? Thank You Eric
boobie
You may want to lube the grease fittings for the tilt tube right in front of the motor.
