power tilt pump
postie
I have a 1975 Glasply with the 165 Mercruiser 1 leg. While tilting up the leg I noticed a lot of oil leaking from the pump unit. It seems to be coming from the gasket that joins two parts of the pump unit together. Does anyone know if gasket kits are available for these pumps?
Bt Doctur
Re: power tilt pump
If its leaking from the valve body ,there just some O rings, the base to body uses a large O ring
postie
Re: power tilt pump
There is a flat base fitted to the main pump unit with a rectangular gasket but there is another irregular shaped piece attached to the bottom of this that has two lines running out of it. It is the gasket between these two pieces that seems to be leaking
