Power Tilt Problems
Seventy
I have a '95 Evinrude 90hp. Recently I started hearing a screeching sound when I lifted the engine up and down. Now the engine doesn't tilt at all but the motor for the power tilt sounds fine. I was told to fill the power tilt with fluid but when I did that the fluid filled then just came out and made a mess and I still have the engine stuck in the up position. Would love some advice from someone...Thanks
Hooty
Re: Power Tilt Problems
You should be able to open the manual relief screw to get the engine back down and then bleed it to see if there's air in the system.<br /><br />c/6<br /><br />Hooty
RC Wilkins
I had the same problem with my 88. follow these instructions provided to me by joe reeves.Raise motor to the top.Suport motor with a block or flip down the motor support. <br />Looking at the back of the motor you will see a 1 inch round cap with a screw driver slot lower left below the pump motor.Remove that and you will see a plunger and a spring.Remove them.On the back of the cap that you removed(this is really a valve)you will see a hole in it.Find a punch to fit in the hole.Now look in where you removed the cap and you will see a hole in a valve that is the same size.Place the punch in that hole and give it a couple of raps with a hammer.Becareful there is a lot of pressure behind that valve and oil will squirt out.You should see the motor come down once you relieve that pressure.Reassemble and fill res with oil.Worked for me
