corrysurveyor
Thread starter- Joined
- Dec 21, 2009
- 11
Howdy Folks!
Having a particular problem with the PTT on my 2000 Nissan Outboard. To begin with, while underway and at rest, it wanted to tilt up by itself and I would have to watch it and tilt it back down. Then it would tilt up but not down. I would push the switch down and it would just click. I reversed the leads from the switch and down makes it tilt up but up does nothing, just click. I changed the down solenoid and it did the same thing. I reversed the leads from the tilt motor (green and blue) to the solenoids and green connected to the up solenoid will make it go down. Again, Up lead (blue) connected to down solenoid just clicks and reversing the leads from the tilt switch has same results as before, anything connected to down solenoid just clicks. Checked all wires with a voltage meter from both switches (on motor and remote at console) all through the diagram and everything has voltage. Wiring overall looks good.
Any help anyone can provide is much appreciated.
