Power Steering Fluid Disappearing.... A Mistery
cbr1574
Can anyone help me.
The hydraulic fluid in my power steering is disappearing. I keep feeling it up every time I go out on the boat for the day.
I look everywhere to see where the fluid I going to and nothing.
Can anyone give a clue, what is happening and where is the fluid going.
Thank so much, for all you guys help.
Sea Ray ? Seville II ? 1986
19 Ft. Cuddy Cabin
Mercruiser 140 HP
Alpha One Outdrive
tractoman
Re: Power Steering Fluid Disappearing.... A Mistery
Crack in the cooler probably and flushing out to the lake.
EddiePetty
...gotta agree with the 'ol tractoman.....but:
Seems kinda odd that the cooler would rupture on the oil side.....usually, due to not winterizing the power steering cooler, the water side will freeze burst and leak water into the steering fluid.
Alpheus
Exactly. You better be careful or you will be right up there with BP and Exxon as far as oil spills...
Don S
Corrosion on the water side of the oil tubes inside the cooler is usually what causes the oil to leak. Usually just a very small pinhole. Removing the cooler and pressure testing the (drained) oil side of the cooler while the cooler is in a bucket of water will show the leak as bubbles.
cbr1574
Can any please tell me how the oil cooler looks like.
Why would it not leak inside of the bilge compartment?
I boat in South Florida (Fort Lauderdale) no need to winterize the engine.
Thank you, so much once more.
a70eliminator
It's a tiny shell and tube heat exchanger, steering fluid flows through a tube surrounded by water flowing through the shell, if a tube is compromised than oil will leak into the shell and a mixture of oil and water will be carried through the cooling system and discharged out the exhaust.
christoner2002
Anyone know where these are available? It
looks like they are no longer available from MerCruiser.
cbr1574
Hello ,,,,, once more
Is there anyway of testing the power steering fluid cooler?
Just want to make sure it?s the problem. I did a search and I saw they are not that cheap to replace.
Thank you
CheeseCutter
Don did explain how to test/confirm:
Alpheus
Its the problem. You said it yourself. If there is absolutely no evidence of a leak inside your boat then that is the only other place it could be. Power Steering fluid doesn't evaporate...
Welcome to the wonderful world of boat ownership...:D:D:D
If it flies, floats or F**ks, you are better off renting it.
chaparall villain 2
check on ebay i looked aat one time and there were a number of them on there .... if fluid is leaking it would leak into the outer water tube that cools it then run through the engine and out the back and you would never see it
