power steering fluid cooler
kailec00
I am posting this after reading Mordekai's post:
I just received a recall notice in the mail about mercruiser engines and the issue with the power steering cooler. It is not a straight Tahoe issue, it is with MerCruiser. I contacted my local dealer and they will take care of it. I did not take it to my Tracker dealer, but the Mercuy dealer. Hope this helps ease everyone's mind about it being a Tahoe issue.
MelodyBay
Re: power steering fluid cooler
Thanks for the update. Is this recall for 2010's only?
kailec00
I asked the dealer today when I took the boat by for them to inspect. He said that it had to do with serial numbers and so much a year. I would suggest looking and taping on the part to see if it is plastic or metal. If you can not tell then take it to your nearest MerCruiser dealer. They will be able to look at it and tell of verify it by serial #.
They had to order the part and it will take 1 to 2 weeks to come in, then 1 day to put on.
MelodyBay
Thanks....I'll be checking mine this weekend.
Haven't received a recall notice yet....that's a good thing.
yourboatmyboat
On your breather cover will be three numbers , it will be one for the engine, one for the drive, and one for the transom. The engines effected on the recall are as follows. serial numbers 1A350037-1A350511
1A601377-1A608988 1G400659-1G401328 1G480598-1G480761
MelodyBay
Just got back from a great weekend of boating......checked out my serial numbers and also the part. All is good as nothing is plastic.
TnForMe2
Mine broke on my brand new Cobalt/Mercruiser with 8 hours on it. Stranded us on the lake and it was a mess. Shortly after we got it towed and fixed, the recall was issued. Make sure that if you have the composite power steering cooler, get the copper one that's worked for years. The composite (plastic) piece is junk.
yourboatmyboat
Have you seen the latest in recalls ??? Even Mercedes Benze is not exempt. 85,000 , 2010 modle , cars recalled because of crashes do to steering problems
