Power Steering Belt Removal Mercruiser 3.0
juice69
I have to be mechanically dumb. Or maybe I'm getting old and losing my mind, because I know I've removed the power steering belt before to change the alternator belt. I will claim I haven't spent a whole lot of time on this though! I've loosened the power steering hinge, but I'm unable to slip the belt off due to the large bolt that's in the way. I'm sure I could pull this off some good old fashioned force, but my concern is getting the new one on. I can't imagine force being the answer?
I think it's slowly coming back now, don't I remove the port side spacer and slightly jack-up the engine and the power steering belt will slide off?
Re: Power Steering Belt Removal Mercruiser 3.0
Ayuh,... Ya pull the spacer to remove the Alt. belt,...
I'd pull the pulley to get that belt off,... the 4 bolts in yer picture,...
achris
More fish than mountain goat
I'm with Bond-o. Remove the pulley. If you jack the engine you'll mess up the alignment and possibly damage the coupler...
Chris.......
juice69
Does the pulley require a special tool, or does it pop off (with a little extra force)?
achris
Remove 4 bolts. Bump with palm of hand... Pulley falls off...
juice69
Cool, thanks chris (and bondo!).
