power pilot controls
mooseskin
i a 1981 evirinrude 115hp with the power pilot control. under the ignition key and the throttle tension adjuster there is a 3 pronged harness connector. the 3 wires at the connection on the controller are black,purple and gray. i believe this is for the tach,right? anyway heres what i found, the black is ground as i figured, with the key on enginre not running i have 12v on the purple wire and 0.45 on the gray wire. at the other end of the harness the purple wire has tuned into 2 purple wires, one which is hooked up to the tilt/trim gauge which hasn't worked since i got the boat . the black wire also has turned into 2 black wires, one is tied into a group of wires to the gauges for the ground. i have the 3 wires, black,purple and gray that are unhooked that i assume go the tach. nothing is hooked to the tach and this is the way i got the boat. the tach connections are marked so the black will go to the ground connector, what do the purple and gray ones go to? thanks in advance.
Haffiman
Re: power pilot controls
The purple is a fused 12Volt, goes to B+ or 12V on the tach, the gray goes to 'signal'.
