Re: Power Packs
Hi RiL,<br />If someone could show me a connection from the power pack to the battery I maybe could believe it. The power packs are supplied 2 voltages that are AC and are supplied by the stator, and timer base under the flywheel. The powerpacks Changes this AC voltages to DC they store the larger voltage in a capacitor until the timer base says to discharge it to an ignition coil.<br />To answer your question, the battery has nothing to do with the power packs. If however the battery is low you might not be able to spin the engine over fast enough to start it.<br />Hope this clears it up for you.
