Power Pack location 115 Turbo Jet/troubleshoot
Hobie17
i have a 1994 OMC 115 Turbo Jet (inboard) can someone tell me where the power pack is located on the engine - the engine starts fine when cold and runs well at all rpms for about 20-30 minutes, then it shuts off as if the key were turned off - this happened a couple of times under 3/4 throttle....sometimes it will start right up and run for a couple of minutes (but would bog-down like no fuel) then shut off again and will not start.....sometimes she'll just crank over with no hint of a spark....the next morning(s) it fired right up and ran fine again for 30 minutes....is my assumption correct that the power pack is failing? - thank you for any assistance
wilde1j
Re: Power Pack location 115 Turbo Jet/troubleshoot
You can probably confirm it's the PP by heating it with a heat gun or hairdryer while running on the hose. PP is normally to aft of the powerhead (you can easily confirm by looking at the parts diagram for your motor on BRP's website).
Be careful if you use a heat gun not to get to hot!
