Run the motor. Stop the motor. Remove and inspect each plug. Does it look like it's firing? Is the gap correct? While all the plugs are out perform a compression test on each cylinder.
Check the stator output. If it's below 150 volts, it won't fire each plug on every rpm. Must have 150 volts on each connector to each power pack. That will change as the engine heats up. May run fine when cold, and worse as the engine normally warms up. Weak ignition components are very heat-sensitive.
