power loss
captain cadillac
What could make my motor need to run at 4,500rpm to achieve the same speed it it used to run at 3,000rpm? The prop seems good to go and it runs nice and steady with no issues? It sat idle for about 4-5 weeks and I needed to use primer solenoid in manual posistion to get it to start...how long should it take the motor to warm up before I can return the switch back to auto on solenoid? If run in manual posistion will this decrease the power and increase rpm?
mekkamaz
Re: power loss
Can you tell us more about your motor? yr, hp? Also, bottom of boat is clean?
nwcove
Re: power loss
im with mek, more info needed! was the boat in the water for the 5 idle weeks? did you forget to detach the trailer from the boat on you last outing? (kidding).
F_R
Honorary Supreme Mariner
Re: power loss
Any chance the boat has absorbed water? Like in air chambers under the floor?
Tell us more about the remote control. It sounds like you don't really understand it or how to start it. Or maybe it is just the terminology you are using.
captain cadillac
Re: power loss
It's a 60 hp 1999 johnson on a pontoon boat....as I was writing the original post it struck me my problem could have been the primer solenoid.I know I tried to switch it back to auto(red cap facing rear of boat) after it first started and it kept cutting out...the boat smoked alot untill it warmed up.....I may have run it still in the manual position ...is that why it lost power ? If this is the case is my primer solenoid gone bad?
mekkamaz
Re: power loss
Sounds like you have to run on a rich mix in order to keep it going, maybe a vacuum leak or getting somo extra air in the carb due a bad carb gasket. Maybe a dirty carb. Now for the reason that you have to operate the choke solenoid manually, this is cause when you do it thru the key switch it does not work? or it is cause you need more"extra" fuel for start than a couple of shots? That I don?t get clearly...A choke solenoid that is used after a normal cold start, indicates that there?s something wrong with the air/fuel mix. Check also your spark plugs, wear and gap. A bad gapped or worn spark plug can be another power loss reason.
captain cadillac
Re: power loss
I had to manually choke it to get it started..when I pushed the key in (choke posistion ?)and tried to start it would not fire..It seems the auto choke(KEY Operated)is not working...My other question was related to the power loss..Engine revs alot higher rpm (4,500)for the same speed I used to get at(3,000) rpm.If I left the choke switch position on manual and drove the boat that way would that have caused the loss of power and higher reving.For the record..I cleaned & regapped the plugs,changed the fuel filter,changed out fuel and made sure the gas is getting thru the lines ...could poor starting and power loss be connected to the primer solenoid switch position....? It starts if it's (red cap)is to the front of boat If I get it started and push the key in like I was choking it to start....if it stalls the motor will that tell me the auto choke is working? I think the boat runs and idles (once started)way too good to be anything major..I think!
Re: power loss
It sounds like you've got seperate issues going on. First is the fact that you need more rpm's to go the same speed (assuming the tach is correct and you're checking speed with a gps). However, some engine issues (rectifier for example) will render the tach useless. But, IF the tach and speed indication are correct and indeed the engine is revving higher to get the same speed there's something going on with excessive prop slip or else a spun prop hub. 3000 rpm should yield a given speed under the same conditions, PERIOD. 4500 rpm should yield a good bit higher speed than that, no matter what's going on upstream of the gearcase. You've got some slippage, ventillation, or something similar going on with the prop.
As far as the hard starting, yes, problems with the primer solenoid could cause that for sure. If you've manually put it in the bypass position that will cause problems. One thing I'm thinking is that it's probably colder now than the last time you ran the boat several weeks ago. Sometimes 2 strokes can be a pain the the rear to start when it's cold. How long have you had this boat, and have you ever ran it in similar weather?
captain cadillac
Re: power loss
I have visually checked the prop..seems okay and with the boat in gear..I tried to turn the prop by hand and did not feel any slipping past the usual freeplay I thought was normal..The motor responds to the throttle as before (with no hesitation) but just does not have the power boost ...I hear no whinning or racing sound as I accelerate....it's like it turned into a 40hp from a 60hp overnight.....Had the boat since last Dec. full servic on boat has about 20 hrs. since and it was 65 F. in N.C. last weekend.......Could the carbs be a problem(gummed up) if it idles and runs as well as it does?As asked before.. could running the motor with the choke in manual override cause the decrease in power because it was getting alot more gas?
mekkamaz
Re: power loss
If I get you right, you?re asking if one time you forgot to turn choke to auto and worked that way a while can cause this lack of power...I don?t think so. but you have to had issues in idling with choke on, a lot of smoke..stalling...and if you start and part right away at high rpm?s.. a lot of fuel cunsumption...but all this goes away once you return the valve to the auto position. What I think is that if the choke solenoid is burned, the plunger may be stucked in a middle position, giving you a hard time starting and a bad combustion due to the too rich mix. Check if your plugs are black indicating too rich mix. brown they should be.......replace the choke solenoid...again..assuming you?ve thru fuse check and you have voltage in choke terminals, good sw....hope this help...
captain cadillac
Re: power loss
I have heard different versions of what position the choke switch is in for auto or manuel..last was turning the switch clockwise it's on auto..when I did that it started and smoked for a while but ran steady and smooth(plugs were cleaned and regapped ).The plugs actually looked good when I removed them...I would like to settle the choke position switch 1st so I can eliminate that deal.I guess as you said I have a seperate issue on the rpm change....I guess I need to pull the prop and inspect the shaft?Last thing..if I know the primer switch is on auto and I don't here a click or no start when I push the key in and crank it ,is it safe to say the solenoid is dead? you mentioned thru fuse check..where is the solenoid fuse? thanks for helping on this deal...
Re: power loss
The control arm on the primer solenoid should be aligned with the solenoid body when it's in the normal operating position.
A good way to check primer solenoid operation is to activate it with the engine warmed up and idling normally, you should see an rpm drop.
mekkamaz
Re: power loss
Sorry if confuse you, I was generally speaking. There?s no single fuse for the solenoid. Just asking if you checked voltage in solenoid terminals in order to find if maybe is a bad connection, open wire or the solenoid itself. If you have power in your switch, then you have power for the solenoid circuit UNLESS switch is bad. With that said, if all is ok, and voltage is present, solenoid coil is open.
Home Cookin'
Re: power loss
I agree it sounds like two problems.
On the speed issue, your prop is slipping or catching air. If the latter, you would hear it if you have experience with the motor. You can't tell if a hub is spun from turning it by hand; sometimes you can tell by looking at the bushing (looks like bubbles or shavings in the rubber at the rim) but even good props will sometimes show that. Put a mark from the hub through to the prop, dirve around, and if the mark isn't still lined up, your prop is slipping.
In the motor issue, you have plenty of guys under the hood already; I'll just sit over here quietly.
