Power head swap
timsayre
I have a 1979 johnson 140 it won't idle right, has a leaking head gasket on right and i believe a cracked head on left.....also have a 1977 johnson 115, this engine ran great when removed. the reason it was remove was the lower unit is bad, dog gear rounded off. Now for my question can i take the power head off the 115 and replace the 140 with it? I was told by a boat technician the motors are the same and my parts will interchange just not the lower units. Can these be swapped? Thanks for your help.
timsayre
ok i got the numbers off these motors and i was off on years the 115 is model # 115ESL73M and the 140 is model # 140TL77S. So i'm taking that the 115 is a 1973 and 140 is a 1977. The powerhead mounts appear to be in same location. Fatzbullet does this help my situation any in swapping these two. Thanks for your reply to my first question
timsayre
oh well thanks......I took the head off the 140 to fix the blown head gasket and cleared a blockage in the water jacket. I'll fire it up this week and see how it goes. the only other problem i am having with it is idle. it will run at a higher idle no problem but you idle it down to go into gear and it dies out.
V153
Like FB said. They will not match up. In spite of how much you wish they would. Feel yer pain.
emdsapmgr
When that engine idles, the carb butterflys are closed. The small amount of idle air goes the small holes in the butterflys. Fuel is only supplied through the idle passages in the upper carb body. If you crack the throttle slightly, the butterflys will open, and immediately start drawing fuel from the main jets. Sounds like you've got a restriction in the idle passages if it won't idle. A typical problem requiring a carb teardown and cleaning.
