fletchermerc1996
Thread starter- Joined
- Nov 24, 2009
- 19
Hey guys,
So I'm back, hoping for some more advice!!
I have a 1994 Mercury 135 2.0 litre V6 outboard.
It generally runs very well, with no problems. I've had some work done on it, since we brought it 6 months ago.
Prior to me buying the boat, the engine had had quite a bit or work done. Since we have had it, I've had the impeller and housing changed, T-stats changed, and carbs removed, cleaned and rebalanced.
I recently had the engine checked by a mechanic, and he reported that the number two carb was leaking fuel. The problem was corrected and now, when we prime the bulb, it generally gets hard quickly, where as before it didn't.
So, we had the boat out for the week, and had no problems. There was no immediate sign of a fuel leak, until we tilted the engine up, and we would get a small amount of fuel leaking out the back of the engine, into the transom area. This was the same when we got the boat out the water. We removed the cowling, and there was a small pool of fuel at the back of the engine.
I'm assuming this isn't normal and an obvious fire risk. Anyone have any ideas of what might be causing this, if it's not the carbs leaking? Hopefully you can give me some advice or point me in the right direction!!
Cheers
Cheers
