Re: Posting pictures
From faq on top of this page:<br />"Adding Signatures <br />You may use a signature (commonly used in email messages) on your posts. You may set your signature in your member profile. Once you have a signature stored, you can choose to include it with any post you make by checking the "include signature" box when you create your post. This message board's administrator may elect to turn the signature feature off at any time, however. If that is the case, the "include signature" option will not appear when you post a note, even if you have stored a signature. You may change your signature at any time by changing your profile, unless a message board administrator locks your profile. <br /><br />Note: You may not use HTML in your signature file, but you may use
UBB Code . Note that the board administrator may disable the UBB Code Image tag."
