imported_BoatCrazy
- Oct 19, 2006
- 6
I have a 2001 Four Winns 180LE with a 4.3L GL. I was on the lake Saturday with my family (it was finally warm enough and not raining) and we were having a great day wakeboarding. After about two hours of wakeboarding, we decided we would pull into a cove to swim and relax. After floating for about an hour, we decided to go tubing. I hooked the tube up, started the engnie, and idled out of the cove. At this point, everything was still fine. However, when I turned the corner and went to give her some gas, the engine sputtered and died. I tried to refire it multiple times, but I could tell from the sound of the engine it wasn't getting any fuel. I eventually threw the anchor again and took off the flame arrestor and had my brother look down the carb to see if any fuel was being injected as I pumped the throttle (with the key on of course). He wasn't seeing anything. I then decided to take the fuel line off of the carb coming from the pump. Again, no fuel. At that point I gave in and flagged down another boat for a tow.
Here is where it gets interesting. About half way back to the ramp, I decided to give it another try. I gave the throttle a couple pumps, turned the key, and sure enough it started. I had this same scenario happen towards the end of last year, but the only way I was able to get it to restart was to dump fuel down the carb the next morning. I changed the fuel filter during winterization, so I am pretty sure that is not the problem. Last year I thought it might be vapor lock as it was a very hot day and we had run her very hard for an extended period of time before stopping in the cove, but I was under the impression that engines with electric fuel pumps don't vapor lock and it was only about 85 out Saturday. I also read another old post here in the Four Winns area about a '96 with similar issue that turned out to be a "one way siphon valve", but I'm not sure what this is or if my 2001 has one.
Any ideas? I haven't dug into it yet, so I thought I'd ask for any thoughts before I start spending money on a new parts.
Thanks!!!
Thanks!!!
