Possible faulty TPS?
futech
So i was setting up my TPS and the voltage required at closed throttle is .24-.26 volts. My tps only goes as low as this. I get it about 1/3 of the way back and from there to total closed its the same voltage. It goes up to correct place on WOT but doesnt change at lower end to lower voltage. This means i could set it up in different positions for that .24 volts. Does this mean it is faulty?
