woodycooper
Thread starter- Joined
- Sep 6, 2022
- 54
I have just replaced both shaft seals on my E150EXERV. When I pressed the first seal into the carrier I pushed it in possibly too far, but not yet touching the bearing. The outer seal was flush with the carrier and when I pressed the second seal in there is about 1/8 inch gap between the two seals. The diagram in my shop manual shows not much detail but they appear back to back, together with no gap. Is it OK to use as is or do I need to start over? Someone on another forum said they are supposed to be that way and to fill the gap with grease. Any thoughts on this? I can take a photo if needed.
