Porter Cable BN200
alldodge
Having major issues finding parts to rebuild my brad nailer
I need piston ring 180457 which is had to find. Did find it and many call it a O-ring which it's not it's like a piston ring so has a gap. Found it on parts warehouse so have a idea.
Item 113 has one O-ring and the piston ring mentioned previous.
Item 107 has 2 O-rings, one regular and another which was clear and was coming apart. Just have not found the parts needed to rebuild which is really one piston ring and one clear ring which doesn't match up to regular O-rings
flashback
I had a pc finish nailer and all the rubber in it crumbled, I got a harbor freight gun that could use the same nails as I have a bunch. Looked all over for a rebuild kit for the pc ...
alldodge
any chance its a backup ring? (rectangular cross section)
One of the ones on item 113 in first pic has to rings and one of them is square and split like a compression ring.
Just sent a email to Porter to see if they can provide the correct part numbers
If you have a diameter of the piston, groove and groove thickness, should be easy to find from either McMaster Carr or the Hurcules seal catalog.
I would expect Porter-Cable to have a rebuild kit for that nailer. I bought a rebuild kit for my Senco FR framing nailer at Amazon.
tphoyt
I gave up on PG for this very reason years ago.
I could never find parts or a product would just flat out be discontinued with no support at all.
alldodge
I ordered the part yesterday and it's black. The one that was in the tool was like the one on ebay and was crumbling. Figured I'd try the other to see if it last longer. I have about $40 in parts so far and seeing I can get another for slightly over $100, in hind sight maybe it's just throw away
Doing the crown molding in the house, my old Delta nailer went phhlllbbtttt, so I ended up with a Metabo from Amazon or Lowe's the quality is okish but I pull the trigger and a nail comes out
I think these are all now built as "throw away"
