Port side shifter does not hold it's position on Low RPM
HPLou
Just bought a new boat 1989 with 2 Merc 4.3 LXE Ser# OC534197 & Ser# OC454332
And 2 Alpha One Drive Ser# OF162054 & OF162055
The Shift Control is a QuickSilver Link below (same but Older)
http://www.marineengine.com/parts/images/mercury/883711A04.jpg
The Port Side Shifter wants to go back to neutral at low RPM.
I must keep my hand on it until I reach half way (50% travel). At that position and 100% Travel it will stay
in position.
I have no problem with the Starboard Shifter.
Both Shifters will engage OK, Forword & Backword. Neutral Position is OK for Both also.
Is there a Tension adjustment on the Remote Control Port Side Shifter?
ThankYou for your help
Louis
Grub54891
Re: Port side shifter does not hold it's position on Low RPM
Yeah there should be a tension screw under the cover or down lower.
Grub
HPLou
thank's grub1grub2
will look tonight.
Don S
After you take the cover off, you will have to remove the 4 screws holding the unit into the dash or possibly from under the dash to get to the friction adjustment. It's below the handle an inch or so.
HPLou
Thanks Don for the precision.
I will be at my boat this morning.
Will get back if needed.
Louis
