Re: port motor stalls out unless starboard motor is underway
Easy, but I can't quote the exact details. But you can figure it out. On the motor, look at the throttle cable coming back from the remote control. It will be attached to a lever that moves when you operate the fast idle lever on the control. Note that when you have it set on idle speed, that lever is limited/stopped by a knurled screw of some sort. Screw that screw in to increase the idle speed. If you have to move it very far, you may have to adjust the black plastic nut on the throttle cable to match.
DO NOT under any circumstance monkey with the adjustment that limits the full throttle travel!!! You can destroy your motor by messing with that one..
