Zwaky
- May 28, 2018
- 5
Hello folks, I have for the first time in my life acquired a sailing vessel.
It is not much, 13' long by 5' wide. It was practically given to me. With this, l will finally fulfill my dream of learning to sail.
There are repairs to do but I am looking forward to those too. The way I see it, I am ready to do what it takes to pimp this boat to my liking. If it all fails, the learning experience will be worth it.
I have gone sailing several times in the past but I definitely consider myself going into this blindly.
I will document my progress until I hit the water.
I officially declare Project Icarus started!
Day 01
So here is my baby
BIG QUESTION
Where is the boom?!? I am so confused. There is a slot where you can attach one on the mast.
I read that you can sail without a one but it will be hard to go downwind without a system to keep the sail open. What do you guys suggest: keep it that way; buy a boom; make one out of wood?
I made a list of work to do:
Setup and Build Workspace
A good scrup
Patch Fiberglass
New Keel
Restore Rudder and Tiller
Rowing setup
New Lines
Build Boom?
Repaint bottom?
New Pulleys?
Additional Cleats?
Simple Storage area?
There is no keel. I will have to make one.
There is also some damage underneath where the slot is.
I will have to make a new aluminum rail.
Judging from the broken keel and the pin inside the slot. I think this is a centerboard keel. The ones that swing down.
I will have to make one. I will need plans or other examples to give me an idea of the shape and dimensions.
The rudder and tiller look fine. I will recoat them.
These are examples of the more serious fiberglass repairs to be done.
Mast looks great
I have a question. The mast has a track where the mainsail can go in and slide to the top. However the track opens up about 20" from the top and the sail comes loose there. It comes out of the track. Is that normal? Was it bent open? What should I do? There is a rope that it stitched along the edge of the sail.
What is that hook halfway up the mast?
What is that hole in the mast above the rigging attachments?
So this is my project. Wish me luck.
Any help would be appreciated!
Thank you
Day 01
So here is my baby
BIG QUESTION
A good scrup
Patch Fiberglass
New Keel
Rowing setup
New Lines
Build Boom?
Repaint bottom?
New Pulleys?
Additional Cleats?
Mast looks great
Thank you
