Popping noise on 3.0
rosie1
Mercruiser 3.0 engine "popping" noise and loss of power and valves clacking?
Ayuh,.... Welcome Aboard,..... Sounds like detonation from a lean condition or bad timin',...
Fun Times
What year engine is it? Engine serial number handy?
What RPM range do you hear all this at?
Have you pulled the spark plugs to see if there is any type of damage?
Performing a cylinder compression and leak down test might help let you know something too.
Has the ignition timing been moved at all recently?
