Joe Dirt
Thread starter- Joined
- Jul 15, 2006
- 63
Well, I took out my beloved fishing boat this past weekend, for the first time this year. Over the winter, I rebuilt my carb because of the same running issues I had in the fall, but it was the last trip of the season, so I just winterized to work on it this spring. But, it was doing the same thing this spring even after the rebuild.
Started difficultly, and really wouldn't idle. I had to start it, throttle up, and kick it in gear. Once going, it would run on what sounds like one cylinder- and in a deep tone. If I throttled down and tried to throttle back up, it would stall- just as it would if I tried to run at idle.
Over the course of my 10 minutes lake excursion, I had 4-5 "blips" of hope, where it sounded like it wanted to go for a split second stutter, but never did, and never went beyond the 1/2 throttle thing.
So I pulled the plugs when I got home, and one is burning well. The other was fouled, and had oil all over the insulator, tip, etc., so I doubt it was firing.
I figure that since the plug is fouled, it isn't a fuel delivery issue since one is firing, and there is fuel getting to the other one. I'm hedging either a bad plug, or a bad ignition coil?
I have a video of the offending motor if it helps. I'm a car guy, and not so familiar with outboards, just looking for some advice and direction...
Thanks!
Thanks!
