Poor Running 1999 90 HP FICHT
Dpotts4
I have a 99 evinrude 90 FICHT. It idles good besides idling high at 1000rpm. When I try to get on plane it bogs down and falls on its face. Anything over 2000 rpm it spits and sputters. I checked the injectors by having the motor run and pull the wires out and each time I pulled it out it ran like junk so I know the injectors are good. What could it be ?
GA_Boater
Dpotts4 Welcome aboard.
Please try to match your question to the subject of a thread. I never knew FICHT's were 4 strokes, so this is your own thread.
Faztbullet
Test compression first....TPS had problems with breaking. Also check lift pump as could be weak or diaphragm is bad. Also check fuel pressure on high pressure side as could be low. The test you did on injectors just shows its pulsing it still could be bad.
