Poor performance
stonecase
I bought a pro v 16 tracker last year with a new 20hp Mercury 4 stoke. I am only getting about 4600-4700max RPM and about 8-9 mph...the book says the boat weighs about 1100lbs, I am guessing with gear and guys maybe 2000 lbs max...What prop should be on this engine?
steelespike
Re: Poor performance
You are way way under powered.Get the size off the prop near the base of the blades or under the prop nut.Do a test run with just you and no gear.Get us the rpm and speed.
I've seen a 2stroke 25hp 1100lb boat plane at 19mph with 2 guys,fuel and gear. Your rpm is way low because the boat is not planing and isn't likely to plane.Get us those figures and we'll see if you can do it.
