I have a 1971 evinrude 125. I have had several problems with this motor but am unwilling to give up on it. It seems when I run the engine with the muffs it operates just fine, but the minute I put the boat in the water it idles very rough. I will put it in gear and the motor barely chugs forward and then just dies out after a few minutes. I had it on the water working fairly well last week then I spun the prop hub. I did drop the lower unit to replace the impeller between the time it ran well and now. I have noticed mores water spraying out between the exhaust housing and the lower unit. could a bad lower exhaust seal cause my motor to operate like this while it is submerged. also can anyone give me an idea on adjusting the low spped needes on the front of the carbs. the manual doesn't specifically say what the initial adjustment should be (ie. one turn out). <br /> I have replaced the following over the last 2 months:<br />water pump, fuel pump, plugs, wires, timing sensor, ign coil, starting solenoid, electric choke,fuel tank and hose,inspected leaf plates (perfect, cleaned carbs, synched the throttle and distributer.
