Pontoon trolling motor help
Psandherr
Hi guys im getting a pontoon with fishing seats in the back so i dont want a bow mounted trolling motor because it would be hard to control any ideas on what other options i have.
2286 sweetwater fc
22 ft
60 hp merc
tommytoon
Re: Pontoon trolling motor help
get a bow mount trolling motor with a cordless foot controll and your ready. run it from anywhere on the vessel!!
tommytoon
mine was 800.00 new but check craigs list or ebay maybe find one for some swiss instead of cheddar LOL
XtremeCJ
I just recently put the MinnKota Powerdrive V2 Bow Mount on my 22' toon and it works great. Comes with a 18' corded foot pedal that reaches easily to the back, or you can get wireless pedal and / or handheld remote control.
Psandherr
which is better the remote or the wireless pedal
also which is the least expensive
Silvertip
Honorary Supreme Mariner
The wired remote (standard V2) is the cheapest. If the cord isn't long enough, you can cut it, splice in what you need. You might consider running the cord under the deck so you can plug the foot pedal in at the rear and not worry about having the cord laying on the floor..
mrbusdriver
Same with the Power Drive got mine this year and I love it, This past Sat. went out fishing in a downpour and sat under the top with the foot controller in the back worked great.
mrbusdriver
I have a 18 foot Crest and I bought the Minn Kota Power Drive " Pontoon" It's a 54 pound thrust and it came with the removable bracket. It moves my boat just fine even in the wind. The largest you can get in 12 volt is 55 lb. anything bigger is 24 volt.
5150abf
I have a Motor Guide w55 wireless troller, yes they do cost you some cheese but they are worth it, being able to run the boat from anywhere on the boat is really really cool, I have the handheld remote so it is even cooler.
As Busdriver said 55 is as big as you can go without gong to 24 volts and 2 batteries, you probably don't want to go much under that, it takes alot of power to move a toon, especially in the wind.
I have mine on a 16' v bottom fishing boat and it will run it up to 3 mph which is whipping for a troller.
Psandherr
how many pounds of thrust did you get
also 18 ft? for the corded pedal
CJ
You have the same trolling motor I just bought for my pontoon. Although I have not mounted it yet I am looking at the directions and it looks like when I extract the motor from the water the 48 shaft is too long for the 2 ft ledge on the front deck. Did u angle yours? Is it ok to angle it ? Thoughts anyone?
Mine has a 54" shaft and I have to leave my door open when mine is stowed on the bow. (I have a quick mount so if I am not fishing that day it is not mounted on the bow)
Wet_Dream
I just purchased and had the dealer install a 55lb 54" shaft for my Bennington 24SLi (22')- I had the dealer install the 1/2 door in the front. This was the recommended set-up for my boat. My motor is installed in the center of the deck. I went with the Power Drive V2 - corded foot pedal.
Shawn
Todd4
The half door (bottom half of door cut out) is the way to go. If not, can you mount it at an angle? Yes, V-bottom bass boats do it all the time. If you can mount it so it will deploy and stow completely, the angle will not matter. But I suspect you will be hanging off the front quite a bit. Be sure you can still trailer it, too.
Todd
Todd
Thanks, glad to know angling it is an option. what did you use to cut out the bottom half of door (sawzall?). I bought that panel that allows you to lock the trolling motor down, so that should secure it, I guess worse case scenarion if I need to remove it each time and put it back in the truck I could do that
Todd4
My boat came with a "trolling motor" gate (door) where the bottom was already cut out.
Your manuafacturer may sell a matching replacement gate for your boat.
Some have cut their gate and raised the bottom tube of the gate up, fastening with angle aluminum and rivets. Welding may be an option also.
