pontoon sound system thoughts
shaeleblanc
Re: pontoon sound system thoughts
u am going to place it under my back seat in the corner. or under my helm
Intune
well guys i am going to be upgrading my pontoon sound system and wanted to see what other pontoon guys think. i love the speakers i got in my boat now they are clarion 6.5inch in the bottom of the seats. but when i get a few people they get drowned out cause they are so low in the boat so i was looking at adding an amp. well now i am going to be replacing my clarion deck cause it got water in some how. so i am looking at going with a upper end pyle deck and enclosure, 2 more small tower speakers or 2 more 6.5s and looking at still doing about a 600watt amp for everything. i am sure in the distant future i am going to add a self powered sub. but for now i am looking at amps and wondering if you guys think a regular 600 car amp will hold up to the enviroment under my steering console and will a 600 watt amp put to much strain on my single deep cycle battery. if i add some subwoofers then i will add another battery to the system. thanks guys. also i will run my amp remote line to a switch on my dash so i control it on and off.
Hi, I'm not a pontoon owner but I think I can help because of my multiple Holiday Inn stays... :rolleyes:
You need to get your speakers higher. I have a nice system in my SeaRay but the listening environment changes drastically when one stands up.
So, self-contained outdoor speakers such as Bose & Polk Audio work great. I prefer Polk & I use their Momo speaker series in my setup.
http://www.polkaudio.com/homeaudio/atrium/index.php#atrium5
Mount them as high as possible (I wouldn't put them on the top deck railing 'cause that would just be asking to get smacked around but there are a ton of mounting areas on a 'toon.
DON'T get four of these speakers & then try to run your 6.5 seat speakers also for "more" sound. Impedance doesn't work that way & you'll fry your amp. If you really like your 6.5's you could take them out of the seats & build enclosures & mount them higher but I think the Polks would still out perform & without the hassle of building boxes & baffles.
Amps- I use Clarion Marine. http://www.clarion.com/us/en/products/2010/marine/amplifiers/index.html Love them. Real output #'s & made for the vibration & harsh environment they have to operate in. The APX490m would have your boat rockin'!
Amps get hot. Real hot. Don't be surprised if you mount one under your console & it cuts out after 20 mins or so. Add a little cutout with louvers by it so it gets air. I used four of those little rubber feet that go on the ends of wrought-iron lawn furniture to create a stand-off for better air under mine. Little 2.5/3.5" fans are cheap, draw little power & work great at cooling with a bit of hose directing the air across the cooling fins.
"will a 600 watt amp put to much strain on my single deep cycle battery." No. Unless you mean "my single deep cycle battery that is also my motor starting battery." YIKES! :eek: Holy stranded Batman!
You'll be drawing 50-60 amps an hour. A great batt might give you 2 hours. You need a dedicated "start" batt & a "house" deep batt with a switch. Here is one that is a no-brainer (my kind of switch) that charges both but will not let you run the start batt down. A voltage sensitive relay (VSR) is the way to go- http://www.bepmarine.com/125-Amp-Voltage-Sensitive-Relay-%28VSR%29-166-1468.html
I hope this helps you. Have fun!
shaeleblanc
thanks for the reply yea i was talking about my starting battery i will be installing another one now i was looking for the type of switch you posted thanks.
shaeleblanc
ok so would one of them red battery switches work for my setup. the one that has 1 and 2 and off. that switch would allow me to run the start battery and the house battery and swap between the 2 correct.
also my system i picked out will be the mb quart nautic amp 6 channels 4 for highs and 2 for subs thats bridgeable. 1 bazooka 8in marine tube. and then the deck i am looking at trying to get my clarion fixed first.
Intune
That switch will work fine if you remember to switch the switch. :D The VSR is automatic.
That system should rock the boat! :cool:
