Re: pontoon prop question
Propeller Handbook by Dave Gerr has a rule of thumb on page 45 that states engine speed will increase about 450 RPM for every two inch decrease in propeller pitch. If wide open throttle (wot) gives 4800 RPM and the engine is good for 5500 RPM, then the pitch should be decreased by 3 or a 14X10 propeller. A one inch decrease in diameter would also give about the same results, but with reduced efficiency. You have to experiment some to get the right size so try and find someone who will allow you to try several propellers on an exchange basis.
