What have found selling boats, engines, rigging combos, optimizing OB heights and being a boater myself is :
Not all hulls floats same when on plane, some deeper, some higher, depends on hull shape, weight.
Not all boats have same transom height, doesn't matter if being short or long, have found up to 2" height variations. Will depend entirely on fabricator.
Not all OB brands have same lower leg lenghts, doesn't matter if being S-L or XL ones. Some are shorter, some bit longer.
If in pursuit of boating perfection fine tunning OB/trasnsom height for water flow at speed to skim right under upper water deflector plate as in pic, you'll have to deal with the 3 ingredient tech cocktail mentioned above.. This set-up works fantastic for any kind of boat powered by an OB.
Happy Boating
