Pontoon defect (blemish?) on log
BeerSignBilly
I just bought a 2015 Lowe pontoon that is in great shape. However, while swimming around it I noticed what looked like a hairline crack in one of the logs. See attached photo. When rubbing your finger over the "crack" it feels like a scratch. I didn't swim under the pontoon to see if the crack continued around the entire log circumference, but will do so.
The previous owner was unaware of this situation or any issues. He did subsequently speak to the Dealer about it, showing the photo. The Dealer had never seen anything like this before and opined that it was possibly a manufacturing defect, and not a hairline crack since there was no evidence of any leakage. The warranty has expired.
Has anyone seen or heard of this type of defect, problems related thereto, and any remedy?
tphoyt
I’m no pro at this but it looks like a cold shut. Which would be a manufacturer defect.
jlh3rd
never seen anything like that on any pontoon, including my '06 Lowe, or any forum.
If that was a hairline crack, that toon would be full of water.
Maybe looks worse than what it is.
Aluminum experts should step in.
Maybe a good welder could fill it in by welding or brazing.
Honorary Supreme Mariner
???----Pressure test the log and see if any soap bubbles show in that area.
That is concerning.
Looks like a cold crack that should not have made it past the coil stage
Jeff J
I agree with it being a material defect. I like to follow the “if it ain’t broke don’t fix it” mantra so I wouldn’t mess with it as long as it isn’t leaking. A welder could run a bead along it which could be ground and polished so it doesn’t show much.
BeerSignBilly
I finally got around to swimming under the 'toon to inspect the other side of the log, and the blemish/defect does not continue around the circumference of the log; it is only on the outer face. Since there are no other issues I'm going to leave it alone and just keep an eye on things as time goes on.
Thank you for all of the comments!
Jeff J
Welding is not a good idea in my opinion.
Never had a problem with a repaired tube. I’m just a po broke country boy so a couple hundred to a good welder is much preferred to several thousand for a new tube. It costs just as much to ship one as it does to buy one plus a few hundred to have it swapped out if you can’t do it yourself. Locally, they just cut the hangars and weld on the new tube instead of pulling bolts.
jlh3rd
be sure and open up the bleed/drain....whatever you have......as welding on a toon heats up the air and it wants to "blow out" if the drain isn't open.
Scott06
Agreed if a crack drill hole at each end weld from outside in. Nit sure if that is a crack or gouge from when it was rolled due to debris
Mc Tool
In any event that is a stress riser and I believe it wont get any better , and that if that tube is subject to any stress that crack will propagate ( as in go deeper thru the metal until it fully penetrates ) . Being as how the thing is welded together in the 1st place I think that a proficient welder could repair that , and sooner rather than later would be better.
jlh3rd
I agree.
I had an age crack at a seam and a crack at an "M" mount on my original toons ('06). Expert welder with aluminum, no problem.
