jusfloatin
Thread starter- Joined
- Jan 6, 2008
- 295
Good day to all
I recently purchased a couple of Merc 150 (long leg 25") of which one is CCW.
I have no issues with the leg length as I have no problem with the motor sitting a little higher.
1- The concern I have if I use the motor that is the CCW model, is/would there be there any concerns?
My reason for the next question is just that a question
2- Could I run twins between the logs being that the motors I have are 25" legs which would allow me to stick them lower to catch cleaner water?
I understand the're would be a loss in power from having the motor deeper but with the twins that would not be a big concern.
For the curious ones this is a project boat so accommodating the weight of the motors is also a no issue. The pontoon frame and deck has been built with the intention of supporting big horse power.
The pontoons are 25" x 19'3" long (total weight cap. of 4080lbs) The roughly calculated weight without motor and fuel is under a 1000lbs.
