Pontoon anchor recommendatiopn
weesaw
Can anyone recommend a good anchor? I have tries everything to keep my pontoon from drifting.
Teamster
Re: Pontoon anchor recommendatiopn
How long is your anchor line??
It should be two to three times the depth you are fishing,...
Don't forget a three to four foot chain on the anchor end,...
mesajeeper
I have a large box anchor. Has worked great even in high winds. Toss it overboard, let out rode, drag it a couple of feet till it sets and your done. The only downside is that they are a little more expensive than other anchors.
The Rooster
Ensign
+1 on the box anchor. Best we've ever owned. Ours is a bit of overkill @ 25#, but has never failed us. It was pricey, something like $275.00.
arntarchie
It depends mostly on the bottom composition you have to work with. I use a dansforth 20 on sand and clay
MinUph
I too use a danforth style. We moor mainly in sand. I had tried mushroom and they just dragged bottom in a wind. The danforth grips good in the sand. What are you trying to anchor over?
a1nowell
Weesaw,
I have a 24' tritoon, I use a 25# Richter anchor and I am usually in mud bottom lakes. The Richter anchor holds me pretty firm.
Larry
Malibu Rudder
Teamster has the right idea. It is 95% the technique in setting the anchor and plenty of line. Letting out 3 times the amount as the depth of the water should be the shortest you go. If the water is rough you can go up to 7 times the depth of the water. Back up the boat and set the anchor. I use a simply mushroom anchor and it never moves but I am not on tremendously rough waters. :) Good luck.
joebob14
X2 ^^^^I also use a 20# dansforth over sand and mud with no problems. I have seen a lot of different types and they all seem to work if used correctly.
Boobie.Trap
another vote for the box anchor. Add an anchor buddy...golden. Might need some additional line if in deeper water.
Old Screwball
I took the Dansforth anchors out of our old Seadoos. I have 100' of line and 10' of chain on each. 1 has always held the 'toon in place, 2 absolutely, positively keep me in place, current, wind, or boat wakes. Both fit in the rope locker of my Tracker Party Barge.
Capt Sully
Most any anchor will work, it's all in how you set it. You need a lot of scope out, some where around 3 / 7 times your depth. Then you need to set that by use the power from your motor. I mostly boat on lakes, so a river anchor 18lbs works for me. I sure do like my Trac 35 pontoon power wench with remote control.
weesaw
Thanks guys - you've been helpfull. I have tried everything with my old mushroom anchor and nothing worked. I have to change. Sully I like that wench -- my back was crying everytime I pulled up anchor. About every 30 minutes.
