Re: Polyester Resin Question
I think US Composites seems to be the go to on this forum...
at this moment......heh heh heh
welcome to iboats seastar !
best place on the net for boating questions.
first off......poly resin is usually laminated with out wax......wax is a top coat only. if any other thing (besides carpet) is applied to waxed resin....it will not bond.
us comp sells 435 laminating resin.....that is the stuff.
for the top layer of resin/fibreglass....you can add wax.....it is sold as airdry.
air....inhibits (stops) the cure of poly resin so if you use the 435....do a section, and come back a day or two later....it will still be a little sticky....the top is not cured.
treating with wax in the resin....will make it cure hard and also it will also give another water barrier to the glass.
i would also add a layer of 6 oz woven roving over the 2 layers of csm...you need a minimum of 8 oz on the deck for durability.
dont forget to glass UNDER the deck.
