Polaris virage txi 1200
Reellaxn
i believe either my engine is sized or my impeller is jamed. i baught this machine the way it is i got the pistons to move but i need to seperate the engine from the shaft where there is a gray what looks like a coupler from the engine to the pump shaft how do i disconect this so i can check to see if the pump is turning freely ? thanks again for any help
Jeff Walkowiak
Re: Polaris virage txi 1200
best thing to do is remove the pump from the ski, unbolt it and pull it out in most cases the pump liner has swelled up from corrosion and is locking up the impeller preventing the engine from turning
