points gap
Rob Wilkins
I have a champion s1f and I need to check the gap on my points. I am new to this hobby and I'm not sure how to do this. Do I check the gap at the start position or what. I think the gap is .027 but I'm not sure.
Thanks
F_R
Honorary Supreme Mariner
Re: points gap
Throttle position has nothing to do with it. Rotate the crankshaft till the points are open as wide as they go, then adjust the gap to specs. I doubt .027 is correct though. Better recheck your info.
Rob Wilkins
Re: points gap
Yep, your correct. .027 is my plug gap. My point gap should be .018
tmcalavy
Re: points gap
If you don't already have one, pick up a set of feeler gauges at an auto parts store. Indispensable for a points ignition.
