point setting on 2 hp johnson mate
Matt III
there is one line on either side of the word "top" on the cam. i know the points are to be set at .020 but i don't know which line to use(or does i use the word top).Thanks for your help<br />matt
JB
Re: point setting on 2 hp johnson mate
Hi, Matt.<br /><br />Welcome to iboats. :) <br /><br />The .020 should be achieved at maximum point opening, at the "top".<br /><br />Good luck. :)
Chinewalker
FYI - the high point on all OMC point cams is aligned with the crankshaft keyway. Therefore, line up the rider part of the point rocker with the flywheel key and you're golden...<br />- Scott
Matt III
Thanks for such a quick reply<br />matt
