plz help piston compression on mercury sport jet 90hp
Josh122593
What is piston compression supose to be on a mercury 90 hp sport jet 3 cylinder?I tested it today and it was top-125 middle-100 bottom-120.Greatly appreciate any help.
JB
Re: plz help piston compression on mercury sport jet 90hp
Not good. A 10-15% spread is the standard. 25% is too much, but 100psi is too high to be a badly damaged cylinder.
A good decarb might well bring that in line.
Josh122593
thanks i took i to the lake last night and i cudnt barley pass idling speed without it bogging down and me n my dad adjusted the carbs a little bit but it didnt do n e gud so ill just put the new carbs on the motor
Josh122593
do u use sea foam to decarb if not what do u use
JB
I use water, but that is risky. I suggest you use Seafoam.
