Plywood floor- Paint both sides or just one
w2much
Just curious if it is better to just paint one side of the plywood so that it may breath and dry better.What do you think?Thanks.
Tail_Gunner
Re: Plywood floor- Paint both sides or just one
Seal the wood as tight as you can, both sides of course and unless its a cosmetic peice id use a fiberglass resin, Now if your asking do i paint (seal) one side let it dry then do the other?.............. dunno about that........if time permit's what can it hurt......8)
D
DJ
Guest
I've always done both sides.
If you do that, you must make sure that any fasteners that go through are also sealed.
