Plugs getting soaked with gas 1967' johnson 100 hp
Jason1976
1967' johnson 100 hp plugs are getting really wet. Motor has been sitting for almost a year. Is it possible just dirty fuel has made some sticky floats? The wetness seems pretty even in all the cylinders. one seemed drier than the rest. I have checked for spark and everything is working fine.
boobie
Re: Plugs getting soaked with gas 1967' johnson 100 hp
How did you check for spark ?? If you used the spark plug, that won't tell you anything. You need an open air gap spark tester set at 3/8".
Jason1976
I used the plug /: is this a specialty tool ? Can I pick one up at a local napa?
Daviet
Most local auto parts stores sell an air gap spark tester.
Jason1976
Sorry for the duplicate post. I would delete this one. I don't know how?! Thanks for everyone's help!
boobie
Maybe a Moderator will step in and handle it ??
