plugs and gap?
jamesh76
What is the proper plug and gap for 1988 50 hp force. Thanks.
pnwboat
Re: plugs and gap?
If you have a 50HP motor with an ignition system that uses points, use Champion UL81C or RL81C gaped at .030. If you have the electronic ignition, then use Champion L82C or RL82C also gaped at .030.
jamesh76
Re: plugs and gap?
Thank You. I will have to check and see what ignition system I have.
