dzurinko
- Apr 12, 2013
- 65
Looking for an item to plug two holes in my transom. I'm not sure if the item I want even exists but Ill try to explain what it is. The manufacturer had a livewell in this mirrorcraft. The motor (500gph) was attached directly to the transom via two 90? elbows with threads and a nylon nut on the outside of the transom. One was an intake of freshwater and the other was tied into the overflow tube inside the livewell which drained back out. The livewell was inoperative. So the PO simply filled the two elbows with caulk or rubber of some type. As part of my restoration, Ive removed the livewell and elbows leaving two 3/4 inch holes at the bottom of the transom. I dont want to permenently close them with JBweld in case I decide at a later time to buy a new livewell motor and re-install the livewell. So Im looking for some sort two piece solid nylon bushing that I can screw together and seal the two holes for now. Ive done searches on iboats parts store and cant come up with anything. I need like a two piece thing that can screw together and go through one thickness of aluminum and with some 4200 I can seal those holes. Ideas? Know of an item that will do this?
