Plugging holes in transom
Alan_Scott
I'm doing away with the starboard side of the swim deck and have eight of these holes to patch, they had 2" lag bolts run into them BTW. I'm thinking of using wooden dowels coated with epoxy tapped into the holes and leaving them slightly recessed to make room for a final cosmetic repair. Any thoughts?
rickryder
Re: Plugging holes in transom
Mix up some peanut butter and force in the holes... sand and fair low.... cover with gel coat,sand 600,1000,1500 wet... then wheel it out with compound, buff with wax... done ;)
Woodonglass
This ^^^ is true. What is the "Mess" to the side of the holes? It appears to be Silicone. If so, You need to re-do that as well. It will allow water penetration into the transom. 3M 4200 is the sealant of choice.
CaptainKickback
What method do you use to "force" the PB into the holes? Once I add chopped strand to the mix, I have trouble getting it to push into holes.
Woodonglass
1/8" wooden dowel and putty knife. Scrape...Poke...Scrape.. Poke. No Strand just cabosil
and milled fibers.
Alan_Scott
That "mess" to the right is where someone ran the wiring for a humminbird tranducer and temp probe, from the inside that hole appears to be at least an inch in diameter :facepalm: Not shown is another hole of that size for the speed sensor :facepalm::facepalm:
The boat had a home made kicker mount on the swim platform so I've removed that half of the platform and restoring the transom to install an adjustable mount. I don't think that they missed any opportunities to drill a hole lol
Woodonglass
I would definetly remove, inspect and repair any and all of the PO's previous installations. Your transom must be sealed from any and all water intrusion possibilities.
Yacht Dr.
You really should grind and glass those repairs ..
They are so close together that no matter what you do your going to finish the same area around them.
Do a little bit of 3" grinding and glassing with mat..sand fair.
If you want a gel finish..then let us know :) ..
YD.
