ok here is the problem the engine was a very hard to start and had a miss.i took the flywheel off and found that i had a lot of play in the plate that the points bolt to.so much play that when i would move the plate with the tiller arm i seen that the points where changing gap.i have a doner engine and used the plate and other stuff out of that engine.anyway what kind of wire do i use for the plug wires ? also is there a way to gap the coils away from the flywheel ? i have a manual but its not clear on all that.
