Plug wire length? - 1991 Johnson 120
MNhighpockets
Hi, I'm looking for the plug wire lengths on a 1991 Johnson 120 . I am attempting to get it back on the water after its been sitting for 4-5 years. Initial inspection showed a broken plug wire on one cylinder. Boat is up north several hours at a cabin and I won't be able to measure it myself for a few weeks. I had mistakenly figured there would be a kit for this motor but it appears Sierra sells 6", 9", and 12" wires. Anyone know the correct lengths? Thanks!
Joe Reeves
Since nobody has jumped in here, I thought I'd give it a shot if for no other reason, to get you back to the top of the pile.
In the coil kits that I have in mt remaining stock which ARE NOT for your 1991 V4 looper, the plug wire is 9" long. However my coils, although identical in the coil appearance, DO NOT incorporate the pin terminal for the primary boot but rather have a ground wire and a long orange primary wire.
Frankly, I'd suggest you get the longer coil wire and cut it to length if necessary... or a four foot length of it at your local auto parts store and save $$$$. Just make sure it has a wire core! NOTE:... You may find the following useful.
(Replacing Regular Spark Plug Wires)
(J. Reeves)
If you also need the spark plug boots and the spring terminals that connect to the spark plugs, purchase them from your local dealership (OMC Part #581027). This includes one boot and one spring connector. Price is about $3.25ea.
Purchase whatever amount of spark plug wire you need. Be sure to purchase the kind that has a steel (or copper) twisted wire leading through the center of it....... not the carbon type plug wire that many automobiles now use.
Using your old plug wire, cut the new wire to a length about 3/4" to 1" longer. If you have no old plug wire, just make sure that the wire is longer than you'll need as you can trim the other end later.
The rubber boot, spark plug end.... With the wire cut to the length required, trim back 1/4" insulation again but do not solder tint the wires. Simply fan out the wires and fold them back against the insulation, cutting the excess off as explained above. Holding the spring wire terminal, estimate where the prong should be inserted so that the spring will be flush against the exposed wire. Hold the spring terminal away from the wires end (sideways) and insert the prong into the insulation and into the center wire, then swing the spring terminal in front of the exposed wire portion (makes a tight fit for continuity purposes). Spraying the inner portion of the boot where the wire will insert with a small amount of WD40 makes the installation of the wire a easy project.
Now, the other end that slides into the magneto coil... Look into the awaiting hole of the coil and you will see a somewhat threaded tapered prong. Double check to make sure that the wire is cut to the length required (better slightly longer than shorter), trim back 1/4" insulation again but do not solder tint the wires. Simply fan out the wires and fold them back against the insulation, cutting the excess off as explained above, then simply slide the wire into the coil so that the inner wire core of the wire is impaled by the tapered prong within the coil. That's it.... you're done.
