plug in waterpump?
bska
1979 crestliner merc inline 6 tri hull
-removed block plug antifreeze came out - good
-removed plug on manifold antifreeze came out - good
-fuel stabilizer poured in - good
-removed plug on outdrive, didnt see any water in oil - ok?
-is there a plug somewhere to remove water from waterpump?
new to the boating, anything else im missing? am i ok to fog boat out of water?
thanks
Re: plug in waterpump?
Ayuh,... Welcome Aboard,...
The impeller pump in the drive, self drains when the drive is in the down position....
The circulating water pump on the motor, I take the Big hose off to drain,...
But, I store Dry, No antifreeze...
Btw,... You've already gone past the point of foggin' it, runnin'...
If yer that concerned 'bout it,...
Squirt abit of oil in each cylinder through the spark plug holes, 'n roll it over a couple of times on the starter...
